yellow Posted May 16, 2008 Share Posted May 16, 2008 Having a slight issue... Had the vehicle in for service and asked the guy to check the rear diff as it rumbles on overun (Mostly when I have no force on the drivetrain, most notably between 4th and 5th) He has had the Salisbury diff pan off to check the crown wheel and pignon for play, and he also adjusted the play in the transfer box. Before brining it in, I had changed the flanges and half shafts... RUMBLE is still there.... AARRRRRgggggghhh Not amused! Anyone has other points I could check out before I go totally mad? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 16, 2008 Share Posted May 16, 2008 UJs, they like rumbling on over-run. Quote Link to comment Share on other sites More sharing options...
