cress Posted May 17, 2008 Share Posted May 17, 2008 Hi all, coming back home last weekend down M6, I noticed a bad steering vibration at about 70 MPH. I accelerated to see if it dissapeared at higher speed, this was not the case, it made it worse, and it seemed like the whole car was shaking. I have looked at front bearings etc. They seem ok, the tyres have been on about 3 years and are due for change (Avon AT's). The nearside tyre does seem to be wearing unevenly. Question is; Has anyone come across similar, have I missed something, am I looking in right place etc etc. Thanks in advance Ivan Quote Link to comment Share on other sites More sharing options...
cipx2 Posted May 17, 2008 Share Posted May 17, 2008 I'd suggest to have the tyres changed and properly balanced first, do a test drive and then come back if the steering vibration is still there. If I were you I'd also investigate the cause of the uneven wear on the tyres and I'd start with a wheel alignment check (which is recommended when buying a new set of tyres anyway). Quote Link to comment Share on other sites More sharing options...
Ooops Posted May 17, 2008 Share Posted May 17, 2008 Hi all,coming back home last weekend down M6, I noticed a bad steering vibration at about 70 MPH. I accelerated to see if it dissapeared at higher speed, this was not the case, it made it worse, and it seemed like the whole car was shaking. I have looked at front bearings etc. They seem ok, the tyres have been on about 3 years and are due for change (Avon AT's). The nearside tyre does seem to be wearing unevenly. Question is; Has anyone come across similar, have I missed something, am I looking in right place etc etc. Thanks in advance Ivan I developed a similar but intermittent problem with unidentified and at times severe vibration. I looked at the usual culprits on several occasions but nothing was obvious and I ignored it. Very foolish as eventually the steering pinched, (a first), preventing me from taking a curve. Thankfully it was in the middle of nowhere and I was able to safely pull over. Long story short it turned out to be the steering box which was progressively working it self loose. HTH Olly Quote Link to comment Share on other sites More sharing options...
