8342mat Posted May 18, 2008 Share Posted May 18, 2008 Dropped the key for my 52 reg td5 down the drain, and not able to retreave it, not that it will work again as it fell in the water Anyone suggest best place/ price for replacement. thanks mat Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 18, 2008 Share Posted May 18, 2008 If you get it back take the battery out, run it under some clean cold water and stick it on top of the hot water cylinder in your house for a couple of days, it might wake up ok. I got salt water (much worse) in my mobile phone the other day and did that and it still works fine If you need a replacement then it needs a diagnostic system to program it so the question will probably be who can do this cheapest and the answer is probably an independent outfit Quote Link to comment Share on other sites More sharing options...
