Steve 90 Posted May 20, 2008 Share Posted May 20, 2008 Just looking into swapping the manifolds on my 200 tdi (disco engine in 90) to get the turbo in the defender position. Can anyone tell me if the Turbo's are the same? In other words will I just need manifolds and pipe work to fit my disco turbo to or will I need the whole lot? Cheers. Steve. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 20, 2008 Share Posted May 20, 2008 Got the answer about a minute ago Quote Link to comment Share on other sites More sharing options...
simon red90 Posted May 20, 2008 Share Posted May 20, 2008 Got the answer about a minute ago dont think that is entirely acurate. if you strip the cores out from the housings they are identical. just one large internal circlip and 4 8mm bolts. might need some persuasion. Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted May 21, 2008 Author Share Posted May 21, 2008 Am I right in thinking a 300tdi turbo has the air intake at the rear and exhaust at the fron but is basically set up the same as the 200 disco otherwise? If so does anyone have any pic's? Im actually trying to run my air intake back through the truck cab and have the snorkel on the outside of the rear bulkhead but the 200 disco setup would need a right mess of tight bends etc so I am looking for a better, neater solution. Quote Link to comment Share on other sites More sharing options...
