Tobias Posted May 25, 2008 Share Posted May 25, 2008 I have ran the calcs in three link calculator. Not sure how relevant, since the measurements are somewhat guess work, at least panhard and upper link frame mount. COG is a big guess... 155% AS Rotated the pinion towards the transfer case output, to reduce the gorrible vibrations I had with my previous setup. At the same time converted from radius arms to three link (using radius arms, less rear bolts as lower links) Preliminary testing show good success in both targets. Will have to rotate portal housings by redrilling the bolt holes in the axle flanges to regain caster. one side finished one to go... Sorry for the horrible mobile pictures. T Quote Link to comment Share on other sites More sharing options...
