grumbleweed Posted May 31, 2008 Share Posted May 31, 2008 Having found and fitted my wierd V8 waterpump (thank you Dunsfold DLR) i filled the tank up and went for a drive and found that the fueltank was mostly a mix of rust, holes and leaking fuel. I thought the fuel consumption was a little excessive! Went to Keith Gott to get the new tank and finally fitted it. No more leaking tank and no more dissolving driveway!!! pics to follow. Quote Link to comment Share on other sites More sharing options...
frrfrr Posted May 31, 2008 Share Posted May 31, 2008 hi you should at least get another 2 mpg now that you have sorted the leaks ! Quote Link to comment Share on other sites More sharing options...
grumbleweed Posted June 1, 2008 Author Share Posted June 1, 2008 pics of fuel tank- holes were hidden behind the crossmember! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 1, 2008 Share Posted June 1, 2008 Oh wow that is nasty! Glad mine is plastic that is... until I change it for a shorter/smaller one... Quote Link to comment Share on other sites More sharing options...
