V8SMYMATE Posted June 1, 2008 Share Posted June 1, 2008 Hi i want to remove the air con rad from my V8 disco because when i offroad the mud jams in between the two, and she then could get hot so has anyone done this. If so can give me a few pointers. Thanks Duncan Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted June 1, 2008 Share Posted June 1, 2008 Remove as in permanently? or move it to a less vunerable place? either way see a local air con specialist. Quote Link to comment Share on other sites More sharing options...
V8SMYMATE Posted June 1, 2008 Author Share Posted June 1, 2008 Remove as in permanently? or move it to a less vunerable place?either way see a local air con specialist. I was hoping not to have to do that as the aircon has already empty so i don't think its dangerous anymore hence the question has anyone done this before and did they have any advice thanks duncan Quote Link to comment Share on other sites More sharing options...
lynall Posted June 2, 2008 Share Posted June 2, 2008 Well if its empty simply unbolt the rad and the pipework and throw it in the bin. If you are going to keep at the offroading i would keep the comressor in place and use it as a tyre pump. All the gubbins in the dash can stay there. Lynall Quote Link to comment Share on other sites More sharing options...
V8SMYMATE Posted June 2, 2008 Author Share Posted June 2, 2008 Well if its empty simply unbolt the rad and the pipework and throw it in the bin.If you are going to keep at the offroading i would keep the comressor in place and use it as a tyre pump. All the gubbins in the dash can stay there. I intrested how you can use it as a tyre pump can you explain futher thanks duncan Lynall Quote Link to comment Share on other sites More sharing options...
