toady Posted June 1, 2008 Share Posted June 1, 2008 hello again, i posted on here a couple of weeks ago about the clutch failing on my 300 disco, I was advised it may heve been the fork, but to try the master/slave cylinder first just in case, well done both of these , but ran into a small problem, when i took the slave out the rod came out too with the plastic clip, (see pics) can anyone tell me an easy way to get the little blighter back in?? also by one of the pics, the fork looks ok to me, what do you think?? thanks again for your help Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted June 1, 2008 Share Posted June 1, 2008 a bit of metal tub with a flat washer welded to the end, poke rod throue tub hold it all and push back on and pull tub off the rod Quote Link to comment Share on other sites More sharing options...
