rhydgte Posted June 7, 2008 Share Posted June 7, 2008 Having problems with my diff lock switch being faulty so had a look at taking it out today as I'd bought a replacement (which ended up being the wrong one!). On the T'Box there is another switch that looks exactly the same as the diff lock switch which is not far from it but is not connected to anything - what is this for? I couldn't find reference to it in the haynes... Obviously it should be connected to something!? Many thanks for your time Quote Link to comment Share on other sites More sharing options...
rhydgte Posted June 7, 2008 Author Share Posted June 7, 2008 Oh and one other thing whilst testing it today off road it jumped out of low range twice - what would be the most obvious reason for this? Many thanks Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 8, 2008 Share Posted June 8, 2008 There are potentially 3 switches Reverse light switch on the gearbox Diff lock light switch on the transfer box Hi-low sensing switch on the transfer box - Td5 only The latter is used by Td5s to alter the throttle mapping in low range. Depending on the origin of the t/box there might also be temperature senders on there too. Quote Link to comment Share on other sites More sharing options...
