300TDi Transfer box switches question
rhydgte
Having problems with my diff lock switch being faulty so had a look at taking it out today as I'd bought a replacement (which ended up being the wrong one!).
On the T'Box there is another switch that looks exactly the same as the diff lock switch which is not far from it but is not connected to anything - what is this for? I couldn't find reference to it in the haynes...
Obviously it should be connected to something!?
Many thanks for your time
There are potentially 3 switches
Reverse light switch on the gearbox
Diff lock light switch on the transfer box
Hi-low sensing switch on the transfer box - Td5 only
The latter is used by Td5s to alter the throttle mapping in low range.
Depending on the origin of the t/box there might also be temperature senders on there too.
