pfwilko Posted June 10, 2008 Share Posted June 10, 2008 can anyone tell me if the thinner bolts down the nearside of the head should be done up to a lesser torque than the rest and is there an actual torque setting for the different stages or do you have to use the angle technique? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 10, 2008 Share Posted June 10, 2008 What engine? Les. Quote Link to comment Share on other sites More sharing options...
pfwilko Posted June 11, 2008 Author Share Posted June 11, 2008 its a 200tdi. thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 11, 2008 Share Posted June 11, 2008 Sequence for the 200TDi engine - (stage 1) Tighten all bolts to 40nm (30 lbft) (stage 2) Tighten all 60-deg. (stage 3) Tighten all 60-deg Make sure you use the correct sequence or you will distort the head. Les. Quote Link to comment Share on other sites More sharing options...
