jose Posted June 12, 2008 Share Posted June 12, 2008 The light for dif lock is on aand I haven´t got a diff lock. Also sometimes he TC-ABS light come up. Once I go to the dealer ,diagnostics says no fault.Any idea Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 12, 2008 Share Posted June 12, 2008 There is probably still a diff lock switch though - on some vehicles you can actually engage it with a spanner on the outside of the t/box. I think the ABS is disabled when you do engage it manually like this so that is probably why the light is on. I would guess that the diff lock switch is playing up, if it isn't electrical then you might have a problem with the centre diff if the thing is saying it is in difflock. Quote Link to comment Share on other sites More sharing options...
jose Posted June 21, 2008 Author Share Posted June 21, 2008 The light for dif lock is on aand I haven´t got a diff lock. Also sometimes he TC-ABS light come up. Once I go to the dealer ,diagnostics says no fault.Any idea Quote Link to comment Share on other sites More sharing options...
jose Posted June 21, 2008 Author Share Posted June 21, 2008 There is probably still a diff lock switch though - on some vehicles you can actually engage it with a spanner on the outside of the t/box. I think the ABS is disabled when you do engage it manually like this so that is probably why the light is on.I would guess that the diff lock switch is playing up, if it isn't electrical then you might have a problem with the centre diff if the thing is saying it is in difflock. Thank you for the advice The diff lock is mechanical,I haven´´t got the linkage to conect it. The first light to come up is the diff lock light and after the TC-ABS.Then the dif lock light goes,leaving the TC-ABS on.They check the aAB sensors-slab ecu and now the are going to check the wiring loom.Stil no fault in the diagnostics ( Land rover original) Any more ideas. Thank you jose Quote Link to comment Share on other sites More sharing options...
