gali Posted June 15, 2008 Share Posted June 15, 2008 Hi all, I wish to know how much pressure is recommended for a soft top 110 on wrangler's 35"x12.5x15? Any experience anybody? Gali. Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted June 15, 2008 Share Posted June 15, 2008 It all depends Gali on what you are planning to do, and where you are planning to go. If you are going to do alot of offroad, which I assume you are with MTR's, you could consider lowering the pressures slightly to gain extra traction. However, when back on the road they will need inflating back to a comfortable pressure. Our BFG muds are run at 25-30psi on the road and maybe 18-20psi off road, although they are not as tall as yours. My 34" tyres are run at 8-10psi off road as I have beadlocks. HTH Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 15, 2008 Share Posted June 15, 2008 http://forums.lr4x4.com/index.php?s=&s...st&p=180410 Is your friend Nige Quote Link to comment Share on other sites More sharing options...
