land94 Posted June 16, 2008 Share Posted June 16, 2008 hi hello all i have a defender 300 year 94 tdi i have this doubts what are the symptoms if I have advanced a tooth in the timing belt ? The noise of the engine is very different? because this week i have lissen one year 97 and is mutch more smmothe then mine!! i have a adjust de valve clearance but noise is the same !!i think knocking to mucht , and when a i have pressed the clutch and gear engage the knocking is whorst. could some one help me with this?? best regards josé Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 16, 2008 Share Posted June 16, 2008 Could be too advanced. But without fancy equipment (as we have) you will never know. Quote Link to comment Share on other sites More sharing options...
land94 Posted June 16, 2008 Author Share Posted June 16, 2008 i jimm i hope you are ok!!! you are olowes help a poor portuguese thanks again!! what is you advice? what kind off tool do you use or what you sugest? i change the belt by my self whit 147,000km mow i have 167,000km i think i put in the same place as the original but!!..... not sure. but my sound is diferent from other 300 tdi :( thanks again i now you are an expert in land rover i trust in your point off view. best regard josé Quote Link to comment Share on other sites More sharing options...
land94 Posted June 16, 2008 Author Share Posted June 16, 2008 thanks jimm one ,and one more time what is you advice me? whwn a change the timing the defender has 147.000k and now 170.000km i think i put the belt in the rithe place ,but.... i now my 300 tdi is noise when compared wuth other 300tdi engine,coul be the problem !! what kiind off special tool i need to do this thing rigth , and not think more about thet? thanks again jimm best regards josé Quote Link to comment Share on other sites More sharing options...
