Can you tell me...
Is the power steering box (4 bolt) the same on Classic R/Rovers, Discos and 90s? I need a new box on my 90 and am trying to decide on a recon or 2nd hand from a breakers. If I go for the 2nd hand option I'll get my old box reconed and then tapped so I can add hydro assist later....
When i broke my steering box (i snapped the shaft) i was able to replace it with an identical version from a 300TDi disco, the one thing that you need to make sure of is that with the steering box that you are putting back it is centred on the vheicle that you are taking off or else you might have more lock on one side or the other.
Hope this helps
Tris
