V8SMYMATE Posted June 22, 2008 Share Posted June 22, 2008 I have had this issue on my 96 disco were when i first start the car and pull off the first time i try to brake it feels like the abs is cutting in but no braking seems to be applied (very scary) once you panic and press the pedal again the abs vibration on the pedal goes away and everything is fine. all help needed Duncan Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 22, 2008 Share Posted June 22, 2008 Probably a dud wheel speed sensor, I had a similar thing on my old one once Quote Link to comment Share on other sites More sharing options...
