Jason2 Posted June 23, 2008 Share Posted June 23, 2008 Hi Got a dammed strange noise on my 1995 300tdi Discovery for a good few months now Dunt do it all the time very intermitant & you can only hear it on tick over seems to be coming from the sump/crank shaft pulley area???? Not water pump,alternator,pas as it still makes the noise with the auxillary belt off. Have a listen http://fr.youtube.com/watch?v=TPo4IrftjO4 Any ideas? Thanks in advance Jason PS Would like to sort it asap as we are off on Hols next week in the old girl (South Spain!) Quote Link to comment Share on other sites More sharing options...
Jason2 Posted June 23, 2008 Author Share Posted June 23, 2008 Cam belt tensioner bearing???? All changed 20k ago! Quote Link to comment Share on other sites More sharing options...
DiscoTDi Posted June 23, 2008 Share Posted June 23, 2008 sounds like a scraping sort of noise - is that the noise ? based on the frequency and nature of the noise it could it be something to do with the camshaft timing belt/tensioner assembly area ? The cam belt runs at half crankshaft speed, so say 300 RPM at tickover and the noise seems to come in two's with about a sec gap between, I can imagine the speed of the cam belt traveling around the pullies would coincide with the frequency of the noise when it occurs. Wip the cam belt cover off and have a look ? Do I get a prize if I'm correct ? Good luck Quote Link to comment Share on other sites More sharing options...
lynall Posted June 23, 2008 Share Posted June 23, 2008 Crank pulley tight? Lynall Quote Link to comment Share on other sites More sharing options...
Jason2 Posted June 23, 2008 Author Share Posted June 23, 2008 When I say intermittant it also stops and starts, not doing it now for example although it was earlier and did'nt hear it at all last week. Not hot/cold related either. Quote Link to comment Share on other sites More sharing options...
DiscoTDi Posted June 24, 2008 Share Posted June 24, 2008 any news yet on the mystery sound ? Quote Link to comment Share on other sites More sharing options...
Jason2 Posted June 25, 2008 Author Share Posted June 25, 2008 any news yet on the mystery sound ? You will have to wait a little longer for your prize! Did'nt get chance to have a look yesterday, will try and have a look this morning. Quote Link to comment Share on other sites More sharing options...
Jason2 Posted June 25, 2008 Author Share Posted June 25, 2008 Cam belt tensioner bearing very noisy when you spin it by hand Started a new fred for best thing to do with a noisy visious fan bearing??????????? Quote Link to comment Share on other sites More sharing options...
DiscoTDi Posted June 25, 2008 Share Posted June 25, 2008 glad to hear it's nothing too nasty then Cheers Quote Link to comment Share on other sites More sharing options...
Jason2 Posted June 25, 2008 Author Share Posted June 25, 2008 glad to hear it's nothing too nasty then Cheers Not 100% sure it was the cam belt tensioner bearing yet, time will tell, sure as shell was noisy when I spun it by hand. Cut it in half with angle grinder out of curiosity- No grease-dry as a bone! Quote Link to comment Share on other sites More sharing options...
