Propshaft
Ben1982
Hi,
Can anyone tell me if the propshafts on a 300TDi should slide easily on the center telescopic joint?
I have had to remove the rear shaft and had been told that it should slide like a stiff damper to allow it to move over the pin in the rear diff but mines almost solid tight and will only budge with a hard hit from a hammer.
Reason for removing the shaft was to replace the rubber coupling that looked like it had twisted and had split.
What is the correct 'stiffness' for the shaft? Easy to slide or needing a wallop?
Thanks
Ben
