Boro Posted June 27, 2008 Share Posted June 27, 2008 I have looked in the technical forum but whats involved in replacing the stub axle oil seal on the rear axle of a 95 300 tdi, im doing the rear bearings and outer seals anyway so is it just a case of unbolting the stub axles, replacing the old seals for new, renewing the gaskets and bolting them back on or it it more involved? i only ask as i read somewhere about earlier landrovers (not sure if this applies to the disco or not hence i ask) having a bush in the stub axle Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 28, 2008 Share Posted June 28, 2008 The job is as you describe - I think the 300's are all the same, so there shouldn't be a problem with parts. Make a note of your axle number - just in case though. Les. Quote Link to comment Share on other sites More sharing options...
Boro Posted June 28, 2008 Author Share Posted June 28, 2008 Great cheers les Quote Link to comment Share on other sites More sharing options...
