trt1617 Posted June 29, 2008 Share Posted June 29, 2008 yesterday i removed the gear box from my 2.5 td 90 and replaced a leaking crankshaft oil seal all went well. until a went for a longish drive and when i got home looked underneath and there it was the oil dripping out of the gearbox wadeing plug hole. now im sure i didnt mess the seal up when fitting it. the crank was clean and not pitted the question is any one got an idea why it still leaks? could i have a crank shaft end float issue? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted June 29, 2008 Share Posted June 29, 2008 Did you use a gen seal. I used a copy part when I did mine and had to revisit it very quickly like you. IIRC the gen 1 has green paint or seal stuff on it. It doesn't take a lot to bugger the seal up. It has to go on square using the guide that comes with it. Quote Link to comment Share on other sites More sharing options...
trt1617 Posted June 29, 2008 Author Share Posted June 29, 2008 Did you use a gen seal. I used a copy part when I did mine and had to revisit it very quickly like you. IIRC the gen 1 has green paint or seal stuff on it. It doesn't take a lot to bugger the seal up. It has to go on square using the guide that comes with it. it was a pattern part seal that i fitted and it also came with a guide to fit it over the end of the crank guess ill have to try a lr seal in there thanks Quote Link to comment Share on other sites More sharing options...
