rekab69 Posted June 30, 2008 Share Posted June 30, 2008 Hi Guys, Just swopping over rear disc and calipers from a 98 Td5 onto an older drum braked sailbury axle... Need to know gasket numbers. I found one number FTC3650G... I think.. I have abs / traction control..? I need the outer 6x bolt flange gasket too.. And ... the nuts... numbers... Did i read on here once that it's better to use two nuts (one locking) instead of the single nut....? or did I dream this... How tight do I do them if using two...? do I still need to dial gauge the play...? Thanks in advance Dave Quote Link to comment Share on other sites More sharing options...
