Mike_H Posted August 3, 2008 Share Posted August 3, 2008 Trying to get the RR Classic 3.9 v8 running - '93 Model. I reckon the timing is out, and I can see the notch in the crank damper pulley, but I can't see what I'm supposed to line it up with - I can't see it from above, so I guess I have to go in from the side somewhere (alternator side?). Could someone answer this basic question please! The Haynes manual only goes up to '85, so not for this version (the owner has a 1972 RR as well). Thanks! Quote Link to comment Share on other sites More sharing options...
Mike_H Posted August 3, 2008 Author Share Posted August 3, 2008 Scratch that.... just found them..... although I can't seem to get them to adjust in, because the dizzy vac advance is hitting the hose. Guess I've got the dizzy in the wrong place then! Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted August 3, 2008 Share Posted August 3, 2008 Don't rely on the marks! They are notoriously innacurate. I usually take the plugs out and find TDC on Nº1, then see where the rotor arm is pointing, that will let you know if the dizzy is a tooth or so out. Then time it the old fashioned way, advance a wee bit at a time until it pinks under load, then back off until it doesn't. You'll probably then find that the actual timing as indicated by the marks bears no resemblance to the book settings, mine runs at 16º BTDC, according to the marks.... Quote Link to comment Share on other sites More sharing options...
Mike_H Posted August 3, 2008 Author Share Posted August 3, 2008 I'd double checked with the screwdriver down the bore, and in this case the marks were accurate, as I'd read they often weren't. So I timed it up... had to 'adjust' the vac advance unit to get enough movement in the dizzy, and it idled really nicely, sat at normal temp with the cap off... etc. Shame it overheated and pressurised the hoses when we took it for a run....damn! Quote Link to comment Share on other sites More sharing options...
