kudlinski Posted August 6, 2008 Share Posted August 6, 2008 I recently took my newly purchased discovery to Tixover for a bit of fun (200tdi with an lt77 box). I reversed her off the trailer with no problems at all, however, 30 minutes in I lost reverse completly for the rest of the day. Returning home i have stripped all the trim out above the gear box and it appears that the gear leaver goes into the reverse position but isnt engaging any drive although there is a whiring noise coming from inside the gearbox. Is this a common problem? Whats the best way to fix it? and is it a gearbox out job? Thanks Paul Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 6, 2008 Share Posted August 6, 2008 it sound a bit like the grub screw may have come loose so the fork isn't engaging the gear altho the gear stick and shaft are moving Quote Link to comment Share on other sites More sharing options...
kudlinski Posted August 6, 2008 Author Share Posted August 6, 2008 Thanks for the quick response, can this be got at by taking the top off the gearbox still attached to the truck? Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 6, 2008 Share Posted August 6, 2008 no dont think so i would say it's gear box out Quote Link to comment Share on other sites More sharing options...
