Arthurmullard Posted August 12, 2008 Share Posted August 12, 2008 Hi all, turns out my/our original idea was correct i think it is the flex plate, as i get a different crank speed and faster pump speed! and the scraping whiring noise from the bell housing once the engin stops! any one know the best/easiest way to remove the flex plate? can i slide gearbox back far enough? or is it a remove only? would appreciate any info! Thanks Dave Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 12, 2008 Share Posted August 12, 2008 I've only done manual gearboxes I'm afraid, but as long as they are much the same shape/size, then moving the gearbox back will give you the same approx 6-inches to work in. No clutch in the way, so I would think it would be easier to do. Make sure the torque converter stays in place though. Les. Quote Link to comment Share on other sites More sharing options...
