jim109 Posted August 14, 2008 Share Posted August 14, 2008 Hi Guys, I am currently in the final stages of completing a full restoration of my series III 109 and I have come to fitting the front shocks. The shocks (bought from Paddocks) seem to be about an inch too short at full stroke, when the vehicle is jacked up on that spring. Is this normal and can I just put a ratchet strap around the chassis and spring and pull it up into place or will this just pull the bottom out the shock when the thing goes over a pot-hole?. Cheers. Quote Link to comment Share on other sites More sharing options...
Betsy Posted August 15, 2008 Share Posted August 15, 2008 Thats normal. You can use a ratchet strap to compress the spring, or support the car under the axle to compress the spring. Quote Link to comment Share on other sites More sharing options...
david1701 Posted August 15, 2008 Share Posted August 15, 2008 when i fitted mine i had to compress them a bit to get em on, I jacked to the axle i think, odd, wait for one of the wiser hands to help you as i'm being a tad useless Quote Link to comment Share on other sites More sharing options...
