Yostumpy Posted August 16, 2008 Share Posted August 16, 2008 Looked on their web site today and they list 110 24 spline lh and rh rear halfshafts at £16.50 each + vat!!!!!!!!!!! Are they any good or are they made of cheese!!!!!!!!!!! I've changed the drive members but after a year almost as bad as before, so now I suppose if I change shafts and members . they should wear well together. How easy are the fronts tho' Again thanks in advance. I bow to your superior knowlege!! Stumpy! Quote Link to comment Share on other sites More sharing options...
Marco Posted August 17, 2008 Share Posted August 17, 2008 Looked on their web site today and they list 110 24 spline lh and rh rear halfshafts at £16.50 each + vat!!!!!!!!!!! Are they any good or are they made of cheese!!!!!!!!!!! I've changed the drive members but after a year almost as bad as before, so now I suppose if I change shafts and members . they should wear well together. How easy are the fronts tho' Again thanks in advance. I bow to your superior knowlege!! Stumpy! I guess they are close to cheese..... Suggest OEM parts as all backslash in the drive train will give more stress on all the other bits (diff, UJ's, gearbox). I'm however using the PD HD drive members which seems to be fine (>25.000KM, 127 Tdi, road use) Cheers Marco Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 17, 2008 Share Posted August 17, 2008 I bought a bearmach (not sire how their quality compares to paddocks) V8 90 HD 24 spline shaft for my 90 some years back, running with an ARB in the back and 35" simex. it never broke, or twisted. and was about £25. so cheap doesn't always mean cr@p Quote Link to comment Share on other sites More sharing options...
