Theo disco Posted September 4, 2008 Share Posted September 4, 2008 I am looking for a new set offroad tires, and would like to go bit bigger. Have now Insa Turbo 265/75R16 (are almost 33" tall, much bigger than my spare still unusage Bfg 265/75R16) I want tires also drive controlable onroad. Have anybody 255/85R16 under the discoII??? or bigger??? Best regards Theo Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted September 4, 2008 Share Posted September 4, 2008 i have 255/85/R16 BFG MTs on my disco. they fit no problem with a 2" lift i am a bit light on the back so its got more of a 2.5"-3" lift (wrong springs) but even so you should bo ok Quote Link to comment Share on other sites More sharing options...
Theo disco Posted September 4, 2008 Author Share Posted September 4, 2008 Thanks for the quick answer, looking for mayby even larger. Do you have same ratio diff's 3.54??? What sort of wheelarch extention you have? My car has 2" lift Ome. but is little sag at front. will put bigger springs there. I want still be able to do normal road usage. The Insa Turbo (simex profil) are not very stable on the road, and wear very quick. I had 265-75R16 bfg mud before and they last.... I would like something + 33" or 34" but not to wide!!!! Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted September 4, 2008 Share Posted September 4, 2008 I would highly recommend the super swamper tsl ltb 34/10.5. These offer superb grip in all terrains (apart from tarmac!) are not too wide, not too tall (a 2" lift would be fine) and come in all sorts of rim sizes, 15", 16", 17" I had them and they performed faultlessly. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted September 4, 2008 Share Posted September 4, 2008 the 255/85/r16 is baisically 33.6(34 will be fine) i did some measuring today you can fit 35" on a disco with a 3" lift fine. or on a 2" but the arches have to be chopped more than they are on mine(which is alot) and i am running the same ratios yes...my acceleration hasnt been effected much but then it is quite light! 255 i think is a good with it all fits in with a 7" offset rim and wheel spacers. if you have challange suspention then you may have some problems with a 2" lift, the inner arch fills up very quickley which can cause problems.... i am changing to a bigger tyre soon aswell, 35+. there is nothing wrong with the BFG MT it is a good tyre, well behaved on the road and a fair price if you havnt got your eyes set on some simex extreme treckers or boggers or something else super aggresive then i would buy these, they are also avalable in 35 but are quite wide and are on a 15" rim. hoope that helps. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted September 4, 2008 Share Posted September 4, 2008 hang about. im being thick here and diddnt read the thread properley and wasnt aware we are talking about a TD5. my dad has 265/75 r16 on his TD5 and its fine. we worked out to fit my tyres on his he would need an arch chop. then worked out to fit 35s on it he would need a 3" lift and an arch chop. you wont have to worry about filling up the arches as they are HUGE on a D2 my point still stands. you should be fine Quote Link to comment Share on other sites More sharing options...
