landy lightweight Posted September 14, 2008 Share Posted September 14, 2008 Hey, I'm having some problems with the electrics on a S111 lightweight - can anybody tell me what the function of the 'filter box' (mounted on top of the rocker cover) is and what it does. when I turn on the ignition the dash light is really dim, if I disconnect the supply to the box the dash light goes to normal brightness!! Essentially, nothing works properly - need help. I have replaced the 2 control boxes (behind the seats) and tried a different dynamo (90 amp) Quote Link to comment Share on other sites More sharing options...
Swifty oh no Posted September 18, 2008 Share Posted September 18, 2008 Hey, I'm having some problems with the electrics on a S111 lightweight - can anybody tell me what the function of the 'filter box' (mounted on top of the rocker cover) is and what it does. when I turn on the ignition the dash light is really dim, if I disconnect the supply to the box the dash light goes to normal brightness!! Essentially, nothing works properly - need help. I have replaced the 2 control boxes (behind the seats) and tried a different dynamo (90 amp) The box is a voltage dropper from 24V to 12V for the ignition system. Quote Link to comment Share on other sites More sharing options...
