mabbs Posted September 16, 2008 Share Posted September 16, 2008 RR 1992 3.9 manual, poverty spec with no a/c - thermostat After fitting a new water pump and getting the old girl back into service everything was rosey until yesterday when the temp guage sat at the bottom, and very little heat came through the interior fans, everything points to the thermostat being jammed open- what temp replacement should it be? bearing in mind original spec. I see there are 82 and 88 oc. Shes always sat just below half on the white, like most 3.9s to my knowledge Rich Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted September 18, 2008 Share Posted September 18, 2008 88 degrees ................... 82 degrees was only used in the very early carb models. Quote Link to comment Share on other sites More sharing options...
mabbs Posted September 18, 2008 Author Share Posted September 18, 2008 Thanks for the info! Rich Quote Link to comment Share on other sites More sharing options...
