benbenukuk Posted September 22, 2008 Share Posted September 22, 2008 Hi, I have just had my M.O.T glad to say that it passed I got two advisories both the rear shock bushes, I had replaced them 2-3 months before as they ware shot, Is there any way of getting more from them, I am using std landrover buses and have procomp +5 cheers. Ben Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 22, 2008 Share Posted September 22, 2008 If you are going through shock bushes in 2-3 months then I would suggest that something is wrong. Have you cycled your suspension with the springs out to check if the shocks are bottoming out? My guess is the shock is bottoming out and overstressing the bushes which then fail prematurely. Quote Link to comment Share on other sites More sharing options...
clbarclay Posted September 22, 2008 Share Posted September 22, 2008 I what manner are the bushes failing, are the falling apart or is the joint just loose? If you have the old style of mounts where the joint was held together by a split pin then it can be awkward to keep the bushes tight. Later mounts have a nut so the joint can be tightened more easily. when we were running series LRs on the farm it seemed like every year the bushes on the pinned mounts needed changing to keep the joint tight. Quote Link to comment Share on other sites More sharing options...
