Help Please Clutch Mystery
CLANCY
Hi Guys Can anyone give me some advice I am a novice DIY Land Rover Man? Went out this morning in my 96 300 tdi Defender, all fine clutch and gears all ok, no slip no clutch problems, pedal fine,much the same as normal. Then 2 miles up the road No clutch. Push down pedal same as normal not soft or hard, Checked the Master cylinder by pinching the braided line to the slave cylinder pedal hard. Then removed the Slave cylinder, clutch pedal moved it in and out ok. No leaks in any part and a full reservoir.
I guess the worst senario is that either the clutch fork has failed or the bearing carrier
Tend to agree but would the OP not have found the lever flapping in the breeze when he removed the slave or is it more subtle than that?
Steve
