Peterla Posted October 15, 2008 Share Posted October 15, 2008 Can anyone tell me how hard it is to replace my drivers side front door window. It is electric and any info on how to replace it would be greatly appreciated. Thanks Peter Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted October 15, 2008 Share Posted October 15, 2008 NOt hard but very involved! You have to strip the guts out of the door in a methodical method (get photos as you go a long and make notes of what you remove). You need to remove almost everything and then remove the door frame from the door. This is held on by several bolts, some of which are quite hard to find. When undone the frame slides up and out and the glass can be removed/replaced. Repeat in reverse to reassemble.... good luck Quote Link to comment Share on other sites More sharing options...
Peterla Posted October 16, 2008 Author Share Posted October 16, 2008 Thanks for that, Something I will need to allow some time for. Peter Quote Link to comment Share on other sites More sharing options...
