nige90 Posted October 31, 2008 Share Posted October 31, 2008 Major tinworm on offside inner wheel arch area Easy enough to weld up but very hard to rust proof after. However....if the rear quarter panel is removed it'll be a POP. There's a few obvious bolts to remove, but, how the feck does one separate the mastic bond without bending the panel beyond hope or destroying the paintwork ? Nige Quote Link to comment Share on other sites More sharing options...
disco_al Posted November 1, 2008 Share Posted November 1, 2008 nice sharp knife type implement run along the join between the panels, IIRC from looking through Rave. it's detailed in the body repair section on there Quote Link to comment Share on other sites More sharing options...
drkwack Posted November 1, 2008 Share Posted November 1, 2008 Hi, Ive recently done mine, but I didnt go as far as to remove the panel, remove the inner mud shield/foam strip get a waxoyl set ,remove the wheel gives better access, spray up inside the arch .Lot less hassle and pain also the panel is a pain to get right. Quote Link to comment Share on other sites More sharing options...
