kanggwan Posted November 25, 2008 Share Posted November 25, 2008 Hi there I'm on holiday and have just replaced my SLS airbags with springs (hand was forced due to collapsed left side). There are no places nearby to tell the computer so I was wanting to know exactly which fuses etc to remove so as not to upset the three amigo's too much. I presume the fuse in the main box should be left alone as it seems to be linked to the ABS. In the engine compartment box would just the fuse suffice or should I also remove the relay? Thanks in advance Stewart Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 25, 2008 Share Posted November 25, 2008 I think to stop the maddening bonging noise you need the pooter. Unless someone knows where the thing that makes the bonging noise is - in which case LR tool #1 will fix it. Quote Link to comment Share on other sites More sharing options...
kanggwan Posted November 25, 2008 Author Share Posted November 25, 2008 Funny thing is no bonging at the moment only intermittent hissing of compressor. Maybe it is better to listen to the hissing instead of bonging and leave fuses in? Quote Link to comment Share on other sites More sharing options...
