Chassis modifications...
Is there any way i can modify a galv td5 chassis to accommodate my V8 engine without effectively destroying the chassis?
I ask because ive seen a bargain close to me..
You can cut the mounts off for the td5, and weld on the appropriate V8 hardware, but you will need to grind off the galv first.
You can then get some cold galv and paint that on.
