jimhar Posted December 17, 2008 Share Posted December 17, 2008 I have got a intermitent fault with the front drivers window. Recently replaced the regulator and all working fine but suddenly stopped working, the switches are all fine any help please???? Quote Link to comment Share on other sites More sharing options...
orangemach5 Posted December 17, 2008 Share Posted December 17, 2008 I have got a intermitent fault with the front drivers window. Recently replaced the regulator and all working fine but suddenly stopped working, the switches are all fine any help please???? Did you just replace the regulator or the motor aswell? I assume you have checked the fuses? Take the door panel off and check you have a feed at the motor plug when you operate the switch, its probably a sticky motor. Usually a wack will free them up but eventually it will stick again so its best to source a replacement! Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted December 17, 2008 Share Posted December 17, 2008 I wonder how many people grease the teeth, mechanism, slides & blocks & other moving parts when they have gone this far? Not saying this is your problem, but it could be stuck but ok electrically. You will need to remove the card again unfortunately. Quote Link to comment Share on other sites More sharing options...
