CosZuki Posted January 7, 2009 Share Posted January 7, 2009 Anyone know the belt sizes for the alt and i guess the water pump belt anyhoo in simple terms the wee short yin and the big long one on the front of the engine. Its a 93 L plate disco. PAS present but no AC if that helps. The monkey in the Finnish halfords told me there is a choice of 8!! WTF that cant be right but removing it in the car park in minus 15 is not an option right now!! Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted January 8, 2009 Share Posted January 8, 2009 I recently had the same problem on my V8 - assuming yours still has the same engine and configuration that it left the factory with (and mine doesn't) then a Land Rover agent should be able to sort it out from the chassis number In my case I ended up borrowing several belts that were approximately the right size (I measured them with string and took the string with me) and then returning the ones I didn't use. I guess you could do the same with Halfords, but you would have to buy rather than borrow and then get a refund... Shouldn't be a problem if your Halfords are anything like mine Roger p.s. Measure with string around the outside of the belt while fitted and then around the outside of the new belt for comparison. A used belt will only have stretched a small amount in use (it gets slack because of wear on the inner faces) so get the belt that your string just nicely fits around. Measuring around the pulleys with string doesn't work because it will sit in the bottom of the groove and the belt sits on the sides. If getting them off the shelf for yourself, don't forget there are different widths too. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted January 8, 2009 Share Posted January 8, 2009 The EPC lists the following belts for the 12L 200tdi engine: - PAS and fan belt: ERR810 - which is Dayco 13A1025C, where 13=width in mm, A=automotive, 1025=length in mm (1025 mm) - alternator belt: ETC7469 - which is Dayco 10A0605C, where 10=width in mm, A=automotive, 0605=length in mm (605 mm) Quote Link to comment Share on other sites More sharing options...
CosZuki Posted January 9, 2009 Author Share Posted January 9, 2009 thanks cip Quote Link to comment Share on other sites More sharing options...
