Stretchie_ Posted January 8, 2009 Share Posted January 8, 2009 Does anyone know what size of hose connects to the washer pumps? I need to buy some new hose and unions/stops, whatever you call the little plastic bits that stop the water flowing out unless the pump is activated. There's soooo many different sizes of hose, last thing I need is to buy 10 meters of the stuff to find out it'd the wrong size ; ) Do you also know if I could use it for bleeding the brakes, is it the same size hose that fits the bleed nipples on the calipers? Cheers Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted January 8, 2009 Share Posted January 8, 2009 4mm inside diameter. Not often I'll do this, but Halfrauds sell it in packs and the non-return valves as well - dont get a universal pump from them though as the electrical connectors wont fit...... Or, do like me and get yersell down the scrappies - I fill my pockets with this type of stuff every trip! Quote Link to comment Share on other sites More sharing options...
