lenny the lanny Posted January 25, 2009 Share Posted January 25, 2009 hI guys next problem temp gauge showing running hot so changed thermostat and switch type green as advised but still showing very hot had the engine checked with thermol meter and is running in the mid 70s do I need to change the gauge any surgestions graham Quote Link to comment Share on other sites More sharing options...
lenny the lanny Posted January 25, 2009 Author Share Posted January 25, 2009 hI guys next problem temp gauge showing running hot so changed thermostat and switch type green as advised but still showing very hot had the engine checked with thermol meter and is running in the mid 70s do I need to change the gauge any surgestions graham forgot to mention its my 110 300 Quote Link to comment Share on other sites More sharing options...
samtope Posted January 25, 2009 Share Posted January 25, 2009 My series also reads hot, I also put in a new thermostat and also found the reading not to change. I know that its all fine under the bonnet so went to plan B and chose not to worry about it any more. So far this is working for me, as long as the needle doesnt move too far from what I've become used to.. Post up again if the new guage fixes it! Quote Link to comment Share on other sites More sharing options...
