CURLY Posted February 2, 2009 Share Posted February 2, 2009 Hi, I have a disco 300 tdi and need new injectors. The ones I have are the fly by wire ones with one of them being instrumented, (it's got a wire coming out the side with a plug on it) 2 questions, 1: can they be refurbished? 2: Or does anyone have a set forsale? The wire is coming out, and I think it's had it.. Curly Quote Link to comment Share on other sites More sharing options...
FridaT Posted February 3, 2009 Share Posted February 3, 2009 Hi, I have a disco 300 tdi and need new injectors.The ones I have are the fly by wire ones with one of them being instrumented, (it's got a wire coming out the side with a plug on it) 2 questions, 1: can they be refurbished? 2: Or does anyone have a set forsale? The wire is coming out, and I think it's had it.. Curly Yes they can be refurbished. Any competent fuel injection specialist such as Watson Diesel in Wimbledon for example should be able to do this for you FridaT www.turner-engineering.co.uk Quote Link to comment Share on other sites More sharing options...
CURLY Posted February 4, 2009 Author Share Posted February 4, 2009 Yes they can be refurbished. Any competent fuel injection specialist such as Watson Diesel in Wimbledon for example should be able to do this for you FridaT www.turner-engineering.co.uk hi Frida!, its sam, i got the 300 tdi head from you, then the injectors, then the head locating collet things etc etc, all together now, just need some oil, a turbo hose ~(cos it was split)~ and a bit of luck! thanks for all your help and knowledge! Sam Quote Link to comment Share on other sites More sharing options...
