tel Posted February 3, 2009 Share Posted February 3, 2009 as title says has anyone done this as im going to put some in mine as dont want fixed back buckets if yes how did you go about it pics would be great also Quote Link to comment Share on other sites More sharing options...
Brookers Posted February 5, 2009 Share Posted February 5, 2009 as title says has anyone done this as im going to put some in mine as dont want fixed back buckets if yes how did you go about it pics would be great also IIRC Overfinch fitted Recaro's to their classic conversions so it can be done. HTH Brookers Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted February 5, 2009 Share Posted February 5, 2009 I fitted them to my Disco (previously a 4 door. I just knocked up some adapter frames that picked up the 4 mounting bolts on the Disco subframe and the 4 bolting points on the base of the recaros. If you remove the ford subframes you will find the seats actually have a flat base with 4 bolt holes in the corners so it is relatively simple to make the adapter. Heres a pic of them fitted in the Disco. Quote Link to comment Share on other sites More sharing options...
tel Posted February 5, 2009 Author Share Posted February 5, 2009 thats exactly what im looking to do i prefer the saff cossie seats the lower bolsters are lower thanks for the pic mate what did you do about the seatbelt buckle Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted February 6, 2009 Share Posted February 6, 2009 Well spotted, thay are from a saffire cossie, hence no tilt forward function (which would have been useful!). The seatbelt buckle is part of the ford subframe that i threw away if I remember. The disco one is fixed to the transmision tunnel so was not an issue. Not sure how it is on the rangie sorry. Quote Link to comment Share on other sites More sharing options...
tel Posted February 6, 2009 Author Share Posted February 6, 2009 ahh this is where im stuck as mine is actually on the seat frame its self so id have to find alternate buckles do you have any more pics of them fitted? Quote Link to comment Share on other sites More sharing options...
