baldy Posted February 5, 2009 Share Posted February 5, 2009 Today's silly question ..... After clouting the silly lower valence with the fog lights in on our Disco1 time has come to remove it ! So looked through the manuel last night and cannot see anything about how to remove it does it just unclip ? somehow and what do I do with the wires going to the fog lights. Cheers Baldy Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted February 5, 2009 Share Posted February 5, 2009 Its held on by screws into the bumper end caps and then a row of bolts along the bottom edge of the metal bumper itself (4 of which double as the mounting bolts for the fog-lamp frames). If you do take it off you'll need to cut the end caps down to suit and the wiring from the fogs just tucks up behind the headlamps or take it off altogether by disconnecting it from the connectors behind the headlamps......... Quote Link to comment Share on other sites More sharing options...
baldy Posted February 6, 2009 Author Share Posted February 6, 2009 Its held on by screws into the bumper end caps and then a row of bolts along the bottom edge of the metal bumper itself (4 of which double as the mounting bolts for the fog-lamp frames). If you do take it off you'll need to cut the end caps down to suit and the wiring from the fogs just tucks up behind the headlamps or take it off altogether by disconnecting it from the connectors behind the headlamps......... Thanks mate appreciated Now if it's dry this weekend Baldy Quote Link to comment Share on other sites More sharing options...
