clemo2k1 Posted February 10, 2009 Share Posted February 10, 2009 evening all i have a 300 tdi disco and can hear a noise that's defiantly turbo related ive checked all the pipes for leaks it sounds like leaking air is their a possibility its the bearing in the turbo? and are they servicabe? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 10, 2009 Share Posted February 10, 2009 Turbo's whistle above about 2500 revs and this is perfectly normal. Leaks in the various hoses will produce a rushing sound - especially at higher revs. Les. Quote Link to comment Share on other sites More sharing options...
clemo2k1 Posted February 11, 2009 Author Share Posted February 11, 2009 cheers les ill do some more investigations into leaks Quote Link to comment Share on other sites More sharing options...
antichrist Posted February 11, 2009 Share Posted February 11, 2009 Turbos are indeed serviceable, and you can replace just the bearings, and that could be a DIY. However if you're taking it apart you might as well have it cleaned up and the compressor and wheel and turbine shaft/wheel balanced at the same time. The balancing would have to be done by a turbo rebuilder. If you don't have one near you it could be done by post, just sending them the two components. I'd follow others' advice before going to that extreme however. Quote Link to comment Share on other sites More sharing options...
