PS_Bond Posted March 9, 2010 Share Posted March 9, 2010 so how would lock a 300tdi auto to get the bolt undo with no slot through the bell housing? Doubt the timing pin would withstand the shear force of trying to undo the crankshaft pulley bolt... If you're locking for timing, there's an access cover with 2 bolts on the flywheel housing and a hole in the back face of the drive plate. Locking pin screws into one of the 2 holes (think it's the larger, check the 300tdi engine overhaul manual) and engages in the hole. Quote Link to comment Share on other sites More sharing options...
