300tdi engine mounts
rusty_wingnut
does anybody know if it is possible to purchase the chassis part of the setup?
I have a chassis minus engine mounts and although I could fab up the mounts I'd much rather buy some and weld them on.
Does anybody know who sells them if they are available?
Cheers
give ebay a try
http://cgi.ebay.co.uk/Discovery-Engine-Mou...%3A1|240%3A1318
when i fitted mine i could only find the rubber so i cut my old engine mounts up they wher a perfect 90degree angel to sit on.
give ebay a try
er, thanks :unsure: I am talking about the metal part welded to the chassis that those rubbers bolt into. Also accoridng to my manual they sit 4degrees off horizontal, lower towards the gearbox cross member.
hi
you could try marshlands or richards chassis to see if they would sell you just the mounts as they probably got boxes of them for the production line
HTH
matt
Not a bad idea Matt, will give them a bell.
