RustyNissanPrairie Posted April 28, 2009 Share Posted April 28, 2009 Looking to mount a Sanden air con pump-which I already have from a V8 disco which uses the v belt for use as an onboard air setup. I've searched through the PDF 110 parts manual and found the mounting brackets- BUT where does the pump fit on a 2.5NA ? According to the pics in the parts ID it dosnt look like it fits on the upper side of the timing case towards the fuel injection pump but I could be wrong. Has anyone got a pic of a 2.5NA or equiv with factory fitted aircon or know how it fits? Also has anyone got a 2.5NA Air Con/PAS triple crankshaft pulley for sale? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 28, 2009 Share Posted April 28, 2009 There are four locations for bolts on the timing case, which may or may not be drilled out. I don't have a clean picture, but under this plate. The four bolts holding the plate are them. They are pretty obvious. IIRC, they are M8 tapped directly into the case. Two are on the timing cover and two on the timing case over the timing belt. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted April 29, 2009 Author Share Posted April 29, 2009 There are four locations for bolts on the timing case, which may or may not be drilled out.I don't have a clean picture, but under this plate. The four bolts holding the plate are them. They are pretty obvious. IIRC, they are M8 tapped directly into the case. Two are on the timing cover and two on the timing case over the timing belt. Thanks for the pic-it looks nothing like the drawing in the parts PDF !!! how do you run the compressor-have you got the triple pulley with air-con/PAS? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 29, 2009 Share Posted April 29, 2009 The bracket is a custom made one (I made it one day) for a York compressor. Yes, the 3 groove pulley to run it (ERR3093). Same pulley, all engines. Groove closest to engine is the water pump and alternator, middle is compressor and front is PS. http://forums.lr4x4.com/index.php?showtopic=9759 Here it is on the 2.5NA. Currently it is on a 200TDI. The mounting is exactly the same. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted April 30, 2009 Author Share Posted April 30, 2009 Many thanks Red90 for the pics and link, very helpfull. Quote Link to comment Share on other sites More sharing options...
