tattoed Posted May 5, 2009 Share Posted May 5, 2009 Hi to all ,after stripping n/s because of binding noise found that there was no grease in housing , and stub axle bearing was ground too dust. I cant seem to free the various parts like the brass washer. any ideas???? thanks Quote Link to comment Share on other sites More sharing options...
ashtray Posted May 6, 2009 Share Posted May 6, 2009 i had this problem the other day, haynes manual says refer to land rover dealer for removal of brass bush on inner edge of stub axle, not quite sure of a way of removing, gave up in the end and reused the original stub axle Quote Link to comment Share on other sites More sharing options...
Boro Posted May 6, 2009 Share Posted May 6, 2009 To remove the bearing and seal rest the stub axle on a vice opened sufficiently to allow the bearing and seal to pass through the jaws and carefully tap them out with a hammer and blunt chisel (or similar) from the wheel side of the stub axle, to remove the brass bush on the rear of the stub axle secure the stub axle in the vice being careful not to damage it (nut and bolt through one of the mounting holes) and gently tap a fine chisel or similar behind the bush again being careful not to damage the stub axle, they arent that tight a fit so come off relatively easily Quote Link to comment Share on other sites More sharing options...
tattoed Posted May 7, 2009 Author Share Posted May 7, 2009 Thanks for that but iv given up and im hoping this second hand stub will be sound. One can only cross fingers. Quote Link to comment Share on other sites More sharing options...
