fredy Posted May 30, 2009 Share Posted May 30, 2009 will it add to the top speed if i put on disco 200tdi axles and tranfer box and if it does will it make the engine work not as hard when its doing 60mph i hope it does cause ive all ready bought a dicso will it be hard to change them and what will i need (like new brake pipes things or whatever) so if anybody know anything about it just go on and reply thanks Quote Link to comment Share on other sites More sharing options...
JST Posted May 30, 2009 Share Posted May 30, 2009 axles wont make any difference to the speed T box in the disco is probably 1.2 ratio so you will have less revs at any given speed in high range (low range is the same as your current T box) it will take longer to accelerate but if the engine has the grunt you will have a better top speed. you may need to change the speedo drive pinion when you do the change over too - just use the one from your existing T box its quite an easy changeover as its all unbolt rebolt - a diff lock prop shaft tool would be a useful investment prior to doing the work! forgot to add i am assuming you have a 90, if its a 110 then the rear axle wont be a straight swap - you will need a longer prop - although you would gain discs (over drums?) you would loose a very good reliable diff by changing to the disco axle on a 110 Quote Link to comment Share on other sites More sharing options...
fredy Posted May 30, 2009 Author Share Posted May 30, 2009 thanks alot for that ive got a 90 and iam having it tuned so il have that extra grunt Quote Link to comment Share on other sites More sharing options...
