Desert Cat Posted June 2, 2009 Share Posted June 2, 2009 Hi guys, I'm planning to replace the gearbox filter on my 2001 discovery 2. Does anyone knows how much ATF fluid is required for this operation? RAVE shows information regarding empty gearbox ~ 10 liters, which is not the case while changing filter, some oil cannot be replaced, it's inside the torque converter. "Normal" oil change is about ~ liters, issue is, how much ATF fluid inc. the filter replacement. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 2, 2009 Share Posted June 2, 2009 The filter doesn't take oil in it, it's only the oil that covers it. I would think less than 50 ml more ATF Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted June 2, 2009 Share Posted June 2, 2009 About 4.5 - 5 ltrs will do it. Quote Link to comment Share on other sites More sharing options...
q-rover Posted June 2, 2009 Share Posted June 2, 2009 I usually have 5L on standby. Quote Link to comment Share on other sites More sharing options...
