john01473 Posted June 12, 2009 Share Posted June 12, 2009 yep - left the lights on yesterday and four hours later - el deado - charged battery and now ok. does anyone know of a simple alarm i can install to warn me next time. cheers Biog John. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 13, 2009 Share Posted June 13, 2009 if you want something really simple, get yourself a lights on buzzer from a corsa b or mk3 astra and wire it in. It only has three wires, one live, one to the lights and one to the door switch. To do it properly you should get yourself a two pin switch for the drivers door, otherwise it would buzz when you opened any door. If your lucky the vauxhall door switch might fit the disco so you can get them both at the same time. Quote Link to comment Share on other sites More sharing options...
john01473 Posted June 13, 2009 Author Share Posted June 13, 2009 if you want something really simple, get yourself a lights on buzzer from a corsa b or mk3 astra and wire it in. It only has three wires, one live, one to the lights and one to the door switch.To do it properly you should get yourself a two pin switch for the drivers door, otherwise it would buzz when you opened any door. If your lucky the vauxhall door switch might fit the disco so you can get them both at the same time. THANKS MATE, will give it a try. Big John. Quote Link to comment Share on other sites More sharing options...
